Communication Between Unitronics PLC V560 and rectifier
Hello,
I am trying to communicate V560 with Rectifier through modbus RS485.
PLC pin Details:-
Rectifier Pin details:- pcr01 protocol communication Ver 3_23 EN.pdf
protocol Support:-Mod bus ASCII
        fig 1.0
Please Reply Following Points:
1. Is it possible to communicate Unitronics PLC with Rectifier.
2. If Possible  how to connect between PLC and Rectifier.(PLC RS485 2 wire and Rectifier rs 485 4 wire ).
3. If I short TX+ to RX+ and TX- , RX- and connect A+ and A- terminal to PLC.
    is it okay this way?
4. Shall i need to use converter half duplex to full duplex .
5. Rectifier is Supports only MODBUS ASCII.
    Is it possible to connect as shown in  fig 1.0
Please reply with all possible solution.
