How to create index in arrays, for dynamic reading through index?
I think the possible motion values in the storage block with a statement, between the [ ] where another variable would be placed to indicate the position in the array, the same way it is used in Rockwell and Siemens programs. T
oday the program obliges to create several logics to reach the same objective. The idea is save time?
Example :variable [ index]==>  BLOCK STORE ==> variable to be write
 the index is other variable int , put value the position in array.
  • 3 weeks later...
Ok, thanks for your reply.
Now I have another question. what kind of variables in the "max in array" block can we use? I try to use boolean array to find any in true state, but software indicates error in checking.
In the help d'ont you have information about types for use in this block.
Regards
