Concat two INT16 to single int32
Interroga
I wold like how to make two interger in single variable , with pointer index ?
Example int 1 (bin) = 1010010101010101
int 2 ( bin) = 111111111111111111
start index for 2° int    16 position
result : 111111111111111_ 1010010101010101
In VisiLogic have block for this ( vector fill) . But in unilogic not found this. You can help me.
Regards ,
mauro.
  • Interroga changed the title to HOW TO CONCAT TWO INT 16 IN SINGLE 32, KIND VECTOR POSITION
UniStream doesn't have pre-defined arrays so the functions are necessarily different.
You're showing that you want Int 2 in the upper bytes and Int 1 in the lower bytes.
I would do this old school with combination of a bit shifter on int 2 into a long buffer register and then add int 1.
Tags:
Int_1 - INT16
Int_2 - INT 16
Result -  UINT32
