RBC Posted June 11, 2018 Report Share Posted June 11, 2018 Hi. I recently discovered that a client used a backup to sd card to restore to new factory he build. Can i protect my program to work on only specific plc or can the sd card be restored to any plc. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted June 11, 2018 MVP 2021 Report Share Posted June 11, 2018 I hate when they do that. Bas***ds. Look in the Help under "Licensing". Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted June 11, 2018 MVP 2021 Report Share Posted June 11, 2018 +1 to all of Joe's comment. Also, check your original contract....you might have means to claim if you somewhere mentioned the original as the only build. cheers, Aus Quote Link to comment Share on other sites More sharing options...
