Janeta Posted June 19, 2018 Report Share Posted June 19, 2018 Hello, I'm new in Unitronics. I was created 4 HMI displays and i want to switch them over using the buttons back and forward. The main idea is to switch the first one over the second display and to look through it. I tried with logic in ladder, but I switched the two displays only for a second when I clicked on the button. I want to look through the display until I push the button to switch over the other display. Can anyone help me, please ? Quote Link to comment Share on other sites More sharing options...
Cam Posted June 19, 2018 Report Share Posted June 19, 2018 Take a look at using the jumps found under the jumps and links tab on your HMI Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted June 19, 2018 MVP 2021 Report Share Posted June 19, 2018 Always use positive transition contacts when switching HMI Displays in Ladder. Another option is to use the "Links & Jumps" tab on the display itself to list which bits are linked with which HMI display. FYI, there are example projects that came with your VisiLogic installation that can be very helpful to see how to do things. Also, there is a Unitronics YouTube channel with lots of training videos. Quote Link to comment Share on other sites More sharing options...
Janeta Posted June 23, 2018 Author Report Share Posted June 23, 2018 It worked !!! Thank you soo much for the quick response ! ? Quote Link to comment Share on other sites More sharing options...
