Hi, where can I find MOV command in Visilogic?
Hi,
I'm trying to copy state of the memory bit operand to integer. I would normally use "Mov" command when using RS Ligx software, but I don't know what's the option in Visilogic. Please have a look at the screenshot from RS Logix to havea better idea what I;m  trying to accomplish. Well, I'm a bit lost now, so any advice is appreciate.
And in Logix, aren't you using the same pushbutton?  Don't forget the one shots can work direct from whatever is their ON source in Visi, so you can likely get rid of 4, 5 & 6 and change 0, 1 & 2 to positive transitons.  But as Flex says, there's not quite enough info here to fully decide on this.
cheers,
Aus
