aivaras1 Posted July 5, 2018 Report Share Posted July 5, 2018 Hi all. Im working on some visilogic project and i need to make motor running order rotation. When on button is pressed 1 time motor 1 is running and turn off. When second time on is pressed motor 2 should start. Can someone help with this ? I know i need some memory element, but just can't figure it out. Thanks for help Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 5, 2018 MVP 2021 Report Share Posted July 5, 2018 If there's only 2 motors, I'd do something like this: This is a very simplified version to give you an idea for the logic. You will likely have much more detail in how you start and stop the motors, when they run, etc. 1 Quote Link to comment Share on other sites More sharing options...
