If you're looking to use the same text strings to report the status of your program look at the List of Texts by pointer HMI object.
It will let you type in the fixed text strings you want and select them by changing the value in an MI.  Or you can use the more powerful list of texts by range, which is a bit more work but looks at a range of values in an MI.
Otherwise
3 hours ago, Flex727 said:
What is the source of the text? User input? Pre-defined strings? Data Table? The source makes a difference.
You have tell your doctor specifically what you really want.  Posting your .vlp file with what you've done so far will go a long way to getting the help you are asking for.
Thanks for the quick response, right now I don't have a hole lot other than a text box.  I'm looking into the list of texts right now.    Basically I just want to press a button on the screen and then display on the HMI " process running"  Then say when a input is triggers, I want to change the message to "Process complete" etc.  I was attempting to figure out how to get a string from the library based on an index number but have been unsuccessful.
Paul
Then, Joe's suggestion is likely the best one for you. Use "List of Texts by Pointer". You can type in the strings you need then assign a value to the MI according to which text you want displayed.
