hanchris1 Posted September 18, 2018 Report Share Posted September 18, 2018 Is there a list that defines the various tags inside the program generated STRUCT associated with a given IO Card? For example: adding a UIS-WCS1 module will create a User Defined Tag structure "UIS-WCB1_1". Not every tag has a description associated with it. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 23, 2018 MVP 2021 Report Share Posted September 23, 2018 There is information in the Help under Hardware Configuration such as "I/O Modules: Status and Error Messages". Each module has it's own list. Other than that, the tag descriptions are fairly verbose. Is there something specific you are looking for? Joe T. 1 Quote Link to comment Share on other sites More sharing options...
hanchris1 Posted September 24, 2018 Author Report Share Posted September 24, 2018 Thank you! That is most of what I am looking for. I was also trying to figure out what the "Internal Param" tag was for, specifically for the UIS-WCB1? Quote Link to comment Share on other sites More sharing options...
Saragani Posted September 25, 2018 Report Share Posted September 25, 2018 Internal Param is for internal use. You don't need it. Quote Link to comment Share on other sites More sharing options...
