Perhaps....depends on whether it was "burned".  Does "not communicating with this particular one" mean NO comms at all, or simply it can't read the program which likely means you're in trouble.  But if you have no comms to start with, the user program may have initiated different comms parameters.  Go into info mode and find what the comms parameters are set at,  match them on your PC, and try again.
cheers,
Aus
