Thomasbe Posted November 14, 2018 Report Share Posted November 14, 2018 Im looking for a way to show the physical location of the valve from a feedback signal. Is there an "easy" way to do this without making 100 pictures for scaling 0-100% ? This would be like the Circular Gauge just with the position of the valve instead. Is this something other people are interested in so it could be added in the unilogic software (if so it needs to be dynamic so you can enter the specs of the valve)? Quote Link to comment Share on other sites More sharing options...
bobnorway Posted November 15, 2018 Report Share Posted November 15, 2018 I use only two symbols to build a valve being either light or dark (red or green) whatever you like then dynamicaly activate to show as on or off. By aranging several of these (like a clover leaf) you can easily make all the various valve types, one way, two way, 3 way etc. 1 Quote Link to comment Share on other sites More sharing options...
Thomasbe Posted November 15, 2018 Author Report Share Posted November 15, 2018 This is how it was originally, BUT the customer wanted something more fancy so ....... Im guessing making 100 pictures ranging for 0-100% isnt really ideal for the unistream 15.6 to handle when its multiple 3 way valves (its 4 of them)? Is there no good way of setting this up? Quote Link to comment Share on other sites More sharing options...
HigHTech Posted December 5, 2018 Report Share Posted December 5, 2018 Fancy... I know Unistream can handle a lot of images. I like to push the HMI to the limits and so far Unistream is doing great. In your case you need a nice 3/3 valve. You need a list of 3 images variable to show the actual position. Quote Link to comment Share on other sites More sharing options...
