Guest Zach Posted November 30, 2018 Report Share Posted November 30, 2018 So im using the samba4.3-RA22, it has 2 thermocouple inputs I have my positive and negative leads plugged into the correct slots but I cant get it to read anything, how do I get it to read my thermocouple inputs to my HMI screen, I want it to be a constant temperature reading so I can monitor whether my temperature gets above certain temp. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted November 30, 2018 MVP 2021 Report Share Posted November 30, 2018 Have you set up the Hardware Configuration correctly in the I/O specifications area you first get shown during specifying the plc type? Edit...And also set the internal jumpers correctly? cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted December 2, 2018 MVP 2021 Report Share Posted December 2, 2018 Post your code so we can look at your configuration. Joe T. Quote Link to comment Share on other sites More sharing options...
