marcelo_chaura Posted January 10, 2019 Report Share Posted January 10, 2019 hola , quisiera subir un archivo EDS de un SICK IOLG2EI mediante Ethernet/ip en el software Unilogic . Ya tengo configurada la ip del dispositivo (SICKI IOLG2EI) solo que necesito subir el archivo EDS a Unilogic. Estoy trabajando con PLC+HMI USC-P-B10 15,6" Unitronics. ¿alguien sabe como se realiza esta acción de subir un archivo EDS a Unilogic? SALUDOS. Hello, I would like to upload an EDS file of a SICK IOLG2EI via Ethernet / ip in the Unilogic software. I have already configured the device ip (SICKI IOLG2EI) only that I need to upload the EDS file to Unilogic. I am working with PLC + HMI USC-P-B10 15.6 "Unitronics. Does anyone know how this action is done to upload an EDS file to Unilogic? GREETINGS. Quote Link to comment Share on other sites More sharing options...
Ofir Posted April 16, 2019 Report Share Posted April 16, 2019 Hi, There is no option to load EDS for Ethernet/IP. (There is an option to load EDS for CANopen devices). In this case we suggest to view the EDS file using EDS viewer by ODVA and configure the O2T , T2O and data size manually in UniLogic Ethernet/IP scanner configuration. Quote Link to comment Share on other sites More sharing options...
