Substring variable length
BobH
Yes.
Start by using the "Find Substring" function to the location of the "/" characters.  You may have to call the function a couple of times to find them all - put the separate found locations in separate tags.
Then you can use the "Middle of String" function to extract your data.
I'm not going to post any more here right now because I would like you to try to build this yourself and post your program to see how you're doing.
