Interroga Posted February 26, 2019 Report Share Posted February 26, 2019 I need know how can reset in PID block in state -13 fault. Don't possible set value and value is retentive , same with download this application. now I am with PID locked in state -13. Peale tell me how out this problem. regards. Quote Link to comment Share on other sites More sharing options...
Ofir Posted June 5, 2019 Report Share Posted June 5, 2019 Hi, Which specific PID block are you referring to? - 13 means Autotune aborted. This may result if the Run Autotune element was not called for at least cycle during the autotune, or in the case of an unknown autotune error. You can try using the Reset PID block and then run the PID autotune again but make sure that you are calling the block every scan. Quote Link to comment Share on other sites More sharing options...
