Marin Posted March 2, 2019 Report Share Posted March 2, 2019 Hi There! I am trying to read data and send data to unidrive SK inverter. As for adresses etc on unidrive side, it is all clear, because when i connect with modbus poll software via PC i can read rpm on adress 202 or start/stop drive by sending bit 0 or 1 to adress 629. I am trying to read same with visio 350-35-RA22 but i am not clear do i use right FB's........so before i'll kill myself with uploading new codes over and over could you check what i am missing? I this example i am trying to read status of adress which is 0 or 1 depending is terminal on VFD on or off. So when i press F1 which is set as SB58 i did out on display to show MB1, but, always 0....... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 2, 2019 MVP 2021 Report Share Posted March 2, 2019 Well, first of all, SB 58 should be a Positive Transition contact, not a direct contact. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 2, 2019 MVP 2021 Report Share Posted March 2, 2019 And SB 2 should be a contact, not a coil. Quote Link to comment Share on other sites More sharing options...
Marin Posted March 3, 2019 Author Report Share Posted March 3, 2019 9 hours ago, Flex727 said: And SB 2 should be a contact, not a coil. That was problem....... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted March 3, 2019 MVP 2021 Report Share Posted March 3, 2019 ............so thanks for helping, Flex. Grrrrrrr. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted March 3, 2019 MVP 2021 Report Share Posted March 3, 2019 4 hours ago, Ausman said: ............so thanks for helping, Flex. Quote Link to comment Share on other sites More sharing options...
