israel tal Posted April 30, 2011 Report Share Posted April 30, 2011 I recieve the following error when I try to compile using Visilogic 9.2.0 on my laptop (Win 7 Ultimate) "Runtime Error 2147024770 (8007007e) Automation Error. Module could not be found". I get this error in older ver' and I upgraded to ver' 9.2.0 and still get the same error. in my other computer (desktop xp pro) with the same project in 9.1.0 ver' it work good. I try everything that write in very similar post from 10.8.10 . How can I fixed the problem ? Thank you Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 1, 2011 MVP 2021 Report Share Posted May 1, 2011 I just solved this same problem. The O/S doesn't matter. Here's a copy of my post on the old forum with a link to the file and instructions- This got screwed up when I did a Windows update. If anyone else needs this file, I've posted version 6.1 here: Correct version of xceedzip.dll Just copy this file over the existing one in C:\WINDOWS\system32. You may have to run regsvr32 to re-register it if it doesn't work. Joe T. Quote Link to comment Share on other sites More sharing options...
israel tal Posted May 1, 2011 Author Report Share Posted May 1, 2011 joe hi thank you abut the solution but it isn't work. I speak with the support but they don't know yet. Quote Link to comment Share on other sites More sharing options...
