"PDF Viewer" with Indirect file path (SD)
Has anyone had success with the new "indirect, External SD, path via tag feature? This functionality is pivotal to one of my upcoming projects. I am not having any luck getting it to work with SD card installed in Unistream (\Docs\example.pdf) . If I put sample file in root directory of DOK (USB flash drive) it will open file from filename in tag no issues. I have not tried root directory on SD card. Project direct puts them in "docs" folder. Help file show syntax when file is in subfolders however I have no success. Help, please and thank you.
Hi hotwires,
Regarding the "PDF Viewer" widget when:
The value of the tag ("myTag") assigned to "Path" property should be set like you are in the root of your SD card. For example, for this SD card layout:
    MyDir
        MyFile.pdf
The path will be "/MyDir/MyFile.pdf"
17 hours ago, NoamM said:
Hi hotwires,
    MyDir
        MyFile.pdf
Dan Logee  suggested using   “/Media/Docs/V1210.pdf”
UPDATE: THE ABOVE SYNTAX WORKS ON SD CARD! MUST HAVE /Media/Docs/yourDocHere.pdf
Now to construct a way to make the “/Media/Docs/“ and “.pdf” static and the “pdfFileName” dynamic all in one variable string. I only want to indirectly reference the actual filename portion. Below is what I have so far as a "reference by filename only" indirect path string builder. Is there a better way?
You can use a Message Composer.
Fixed Text with "/Media/Docs/"
Raw Data linked to a filename (ASCII string without the extension)
Fixed text with ".pdf"
Then use the Ladder element Build Message to output a buffer, and then use Buffer to Tag (ASCII String)
  • Like 1
@Saragani
Message composer worked nicely. Now on to FTP client with dynamic filenames. How much can to tell me about the FTP COMPARE? What defines that the file is different for overwrite? File name? File size? Meta data?
I found in help section. No clear definition of what "file is different" means. Assuming filename. Any more context clarity you could provide would be greatly appreciated. I want to develop my application to it's FULLEST potential. Clean, lean, and mean.
Please and Thank You
18 hours ago, Saragani said:
I think it reads the file from the ftp, calculates a checksum on both files and  if its different then it overwrites the original if you selected to.
Checksum driven; THANK YOU for a quick and concise answer. That should work nicely. I stumbled through the process of  fetching a file from PC (Filezilla) to SD via FTP Client on UniStream. I would suggest adding “checksum difference” to FTP help section. “If the files are different” is slightly ambiguitous. My assumption was “filename differences”, if it is indeed a checksum based update then files with the same name could be overwriten. POWERFUL feature, LOVE IT.
