NEDUVASAL Posted May 29, 2019 Report Share Posted May 29, 2019 Dear Sir I am reading a temperature value and dispalying it two screens in hmi . In one screen(PARAMETER) its showing correctly without any problem. But in another screen (TEMPERATURE SCREEN) its not showing anything . The second screen has trends and bargraphs of same MI address . when i remove trends from that screen then its showing value sometimes. samething happened to another parameter also where I had to create new screen and resized trend object to disaply it correctly . Now the same problem is happening with another parameter Temperature. ( Before it was speed parameter) i have attached the program also which is developed in beta version. I WANT TO KNOW WHY THIS IS HAPPENING AND WHY TREND IS AFFECTING DISPALYING A VALUE WHICH SHOULD NOT HAPPEN. Regards neduvasal. BIOFARM FINAL 9KL TEST_draft_kamal.vlp Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 29, 2019 MVP 2021 Report Share Posted May 29, 2019 When I opened your project it immediately wanted the DB defragged. (So I didn't even look at it) If you opening it doesn't bring this up automatically, run it manually from the Build tab and then see how it goes. After downloading/burning the defragged version, don't immediately run it, do a full Initialise and Reset of the PLC and then run. cheers, Aus Quote Link to comment Share on other sites More sharing options...
