chand345 Posted July 8, 2019 Report Share Posted July 8, 2019 Hey, Each day we want to start writing data to a new file. Our file name string is updating fine using the rtc to ascii UDFB, but our store DTI to File status turns 1 when the filename is updated with the new date. Then after another full "day" it becomes -35. However if we never change the filename the data recording continues to work fine. I apologize if this is already explained in another forum but I wasn't able to find one. Thanks for any help your willing to give. Quote Link to comment Share on other sites More sharing options...
Ofir Posted July 9, 2019 Report Share Posted July 9, 2019 Hello, It seems it is required to review the code in order to determine the cause of this issue. Please send a mail to Support@unitronics.com and we will be happy to assist. Quote Link to comment Share on other sites More sharing options...
chand345 Posted July 9, 2019 Author Report Share Posted July 9, 2019 It ended up being because it didn't like the "/" in the date. Makes complete sense, it worked when I used the format that had "-"s instead. However, I would have thought the error code would have been something much more straightforward, like if there was a number for an invalid character or something. Instead it stayed on 1 for a full cycle then turned to -35. Also, the help link (the little question mark in the tool box next to Store DTI to File) doesn't work, I had to click on the load DTI button then navigate in the help window to Store DTI, thought I'd mention it in case the bug hasn't been noticed yet. Thanks Quote Link to comment Share on other sites More sharing options...
