ORSO2001 Posted July 16, 2019 Report Share Posted July 16, 2019 Dears, is possible, during the PID autotune procedure, change the set point value? I mean...if I select "Cycles.Three" the procedure will increase to reach, and go over, 4 times the set point and also decrease 4 time to be below of the set point....is possible set (pass) for each of these 4 steps a different set point?...for example 70, 90, 110, 130? in this way the autotune procedure will be "masked" in what could be a standard start up of the system. thanks Link to comment Share on other sites More sharing options...
AlexUT Posted July 17, 2019 Report Share Posted July 17, 2019 No, it is not recommended. This will disturb to PID Autotune. Set desired SP, then run Autotune. B.R. Link to comment Share on other sites More sharing options...
ORSO2001 Posted July 17, 2019 Author Report Share Posted July 17, 2019 ok...thanks Link to comment Share on other sites More sharing options...
