Marten Posted July 18, 2019 Report Share Posted July 18, 2019 Hi All, I am new to Unictronics and have written an application PLC + HMI with 10 Screens. During test a trend is started, 2 feeds, datasampling (SD card) Sometimes the error HMI application overload popups. Found in the system tags the execution tags, and one is the Pusage tag. It keeps at >90% and sometimes even 100%, Even without VNC/ Webserver or the trend is running Is the overload error related to this? Is this normal an is there a way to reduce panel usage? For example in Siemens you can set the tage update rate. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
NoamM Posted July 18, 2019 Report Share Posted July 18, 2019 Hi Marten, Open a ticket on Unitronics "Help center" at https://support.unitronics.com/index.php the Support team will assist. Quote Link to comment Share on other sites More sharing options...
