juanan Posted September 27, 2019 Report Share Posted September 27, 2019 Hello, I noticed that unilogic has a function named " SQL_QUERY " for executing SQL queries using c language. I can see that it needs to be passed an array of a struct called " SQLParamData_t ". This struct it seems that it has three fields: one for the data type, another one for the data length and finally a third for the data itself. From some try and error I deduced some of this data types values (I hope correctly): unsigned char 1 signed int 4 unsigned int 5 volatile char* 10 Any ideas where I can find the rest of them, for example the value for volatile unsigned char* type? Thanks in advance and best regards, Juanan Quote Link to comment Share on other sites More sharing options...
