Sandeep Posted November 6, 2019 Report Share Posted November 6, 2019 Hello, The problem was in my data logger , after connection of lan then relpy is A connection attempt was failed because the connected party didn't responded after a period of time , The connection failed because connected host has failed to respond 192.168.0.20256 . How should i slove this. 168 Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 6, 2019 Report Share Posted November 6, 2019 Sandeep, Please provide more accurate details. PLC model. Attach test program to see your settings. What software connects to PLC? What protocol used? Connection failed means that you cannot connect. If connection established, then there is other problem. More details - better answer(s). Quote Link to comment Share on other sites More sharing options...
