Creating custom/stacked data tables in Unilogic
Marfla
Hello,
I'm using  US5-B10-B1 controller and want to create a test report. For that ideally I'd like to have table where the column number isn't constant. I attached and example of how I imagined the table.
I wanted to know if its even possible to create 3 data tables: first data table for the top part of the report, second data table for the middle and third for the bottom part and then stack them one on top of the other?
I tried creating some data tables, exporting them into csv and then appending them, but it says its required that the dimensions of the tables match up.
I would really appreciate any alternative ideas.
What says?
12 hours ago, AlexUT said:
combine result in report.
Externally, in Excel or something like that.  This can be done in Excel but you'll have to brush up on your VBA to import three .csv files and format the cells automatically to get it to look like you want.
