project Posted June 9, 2011 Report Share Posted June 9, 2011 Hello, I am french student. I have a PLC Unitronics V 130 and I need help for the PLC. how to write a welcome message? What is the linearization? can we use it for a flowmeter. I did a PLC program and I want to know the bit resettable system for the program duringa fault sensor or controller. To return to the initial state. thank Quote Link to comment Share on other sites More sharing options...
Raul Posted August 4, 2011 Report Share Posted August 4, 2011 Welcome Messages can be set up on the HMI. Just add a text box on the main display and then use links to the different screens you program on your HMI. Hope this helps. Quote Link to comment Share on other sites More sharing options...
