love31o08a@gmail.com Posted February 21, 2020 Report Share Posted February 21, 2020 這個設備使用一年陸續出現致命錯誤大約2〜3個月會出現一次此設備沒有連接VFD由220V經變壓器DC24V使用 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 21, 2020 MVP 2021 Report Share Posted February 21, 2020 Translation: Quote Fatal errors will occur every year after using this device.Approximately every 2 to 3 months This device is not connected to VFD and is used by 220V via transformer DC24V Quote Link to comment Share on other sites More sharing options...
AlexUT Posted February 23, 2020 Report Share Posted February 23, 2020 Hi, Open project in the same VisiLogic you used to download project to PLC. 在用于将项目下载到PLC的同一VisiLogic中打开项目。 Change to Ladder. 更改为梯形图。 Open "Edit->Find Subroutine by Ladder Error Code" 打开“编辑->通过梯形图错误代码查找子例程” Enter code 17 and click OK. 输入代码17,然后单击确定。 VisiLogic will show you subroutine where error being registered. VisiLogic将向您显示在其中注册错误的子例程。 VisiLogic will say "Subroutine not found". VisiLogic将说“找不到子例程”。 Error may be as result of EMI. Then you have to find where the EMI coming frpom. 错误可能是EMI的结果。 然后,您必须找到EMI从何处来。 GOOGLE TRANSLATOR USED Quote Link to comment Share on other sites More sharing options...
