Kevin L Posted April 16, 2020 Report Share Posted April 16, 2020 I can connect to my panel on my laptop, no problem (using TightVNC), but not having any success with Android Apps 9two different apps on two different devices) Returns a connection timed out each time Any thoughts? Quote Link to comment Share on other sites More sharing options...
Dave Posted April 16, 2020 Report Share Posted April 16, 2020 I used VNC Viewer on my Samsung tablet(android), no problems at all Quote Link to comment Share on other sites More sharing options...
AlexUT Posted April 16, 2020 Report Share Posted April 16, 2020 RealVNC from Samsung smartphone is working. Do you use port 5900 or other one if you use Port Forwarding? Quote Link to comment Share on other sites More sharing options...
Rikard Ågren Posted April 17, 2020 Report Share Posted April 17, 2020 Using RealVNC on my iPhone, no problems. Is your phone on the same network as the PLC? Quote Link to comment Share on other sites More sharing options...
Kevin L Posted April 17, 2020 Author Report Share Posted April 17, 2020 Different network Doh! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 17, 2020 MVP 2021 Report Share Posted April 17, 2020 33 minutes ago, Kevin L said: Different network Don't feel bad; I've done that. Amazing what power those four little IP octet values have. A similar thing many of us have done is plug our Ethernet cables into the expansion port on our Vision PLCs. This is a good example of always start troubleshooting at the bottom layer. Like making sure your power is turned on and your wiring is good. Joe T. Quote Link to comment Share on other sites More sharing options...
