gsd Posted April 21, 2020 Report Share Posted April 21, 2020 Hello, If I want my gauges on the HMI to be populated using thermocouple readings, what tag do I link to? See attached screenshot. I've already set the TC type to type J and set the temperature read out to F. I'm just not sure which of these tags will give me the information I'm looking to display. I've ordered the UIS-08TC modules they should be showing up any day now. Thanks for any guidance! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted April 21, 2020 MVP 2021 Report Share Posted April 21, 2020 The data will be in the Value Inputs array. The module returns the data in 0.1 degree resolution, so you'll probably want to divide by 10 into another tag for display. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
gsd Posted May 11, 2020 Author Report Share Posted May 11, 2020 . Quote Link to comment Share on other sites More sharing options...
