Kevin Ferra Posted May 14, 2020 Report Share Posted May 14, 2020 I am trying to pull the program off of a V130-J_TR6 and everytime its gets to "Restoring String Libraries" in the upload process it faults out with "run-time error '6' overflow". What can I do to resolve this problem? Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 14, 2020 MVP 2021 Report Share Posted May 14, 2020 Watch the lower description list carefully. I can't remember how far "Restoring String Libraries" is into the process. Perhaps there is nothing there to upload. That said, did you install Visi using right click/Run as Admin? If not, uninstall using Revo portable, reboot and redo it. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Kerry2000 Posted December 19, 2021 Report Share Posted December 19, 2021 Getting the same error during upload, is there a fix Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted December 19, 2021 MVP 2021 Report Share Posted December 19, 2021 On 5/15/2020 at 9:28 AM, Ausman said: That said, did you install Visi using right click/Run as Admin? If not, uninstall using Revo portable, reboot and redo it. See pinned topic to ensure you do this correctly. https://forum.unitronics.com/topic/7917-visilogic-doesnt-work-properly-after-installation-what-install-as-administrator-really-means/ As the original newbie poster did not respond, we don't know if it cured the issue or not. cheers, Aus Quote Link to comment Share on other sites More sharing options...
