louisgermain6 Posted May 19, 2020 Report Share Posted May 19, 2020 Hey guys, I'm using a US7-B5-TR22 and I'm struggling with this error that I can't resolve using the Store DTI to file element. My goal is basically to convert my DTI to a .csv file to finally populate a Combo Box. What happens is that I have always the same -8 status which is not documented so I can't know what is really wrong in my program. My E parameter is set to "0" and I tried the F parameter with "0", "1" and "2" none of them are making a change on the issue (In my case I should be using or "1" or "2"). When I use the F = "1", it creates me the .udtf files, but the .csv and .csv.zip are not created. Is aynone has an idea on what is happening or has been through the same status error ? Thanks in advance for your help. Louis Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted May 19, 2020 Report Share Posted May 19, 2020 I'm not sure if this is the answer but I remember the file name had to be of specific format, "yourfilename" leave off the csv. Quote Link to comment Share on other sites More sharing options...
louisgermain6 Posted May 20, 2020 Author Report Share Posted May 20, 2020 Hey @Swervomotor thanks for your answer. Yeah in the help file they specify that the name should be without path and I also suppose extensions. So as required my filename is as simple as it can. (Having an extesnsion or a path in the name should introduce another error code I think) I don't think that this status code error comes from the filename entry... Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted May 20, 2020 MVP 2021 Report Share Posted May 20, 2020 louis, I deleted all the repeated copies of the above post that you had done. You were likely thinking "Why didn't it come up?" Well......all posts on this forum are subject to moderation. This is mainly done by a few volunteers scattered around the globe, so sometimes it can take a few hours at least. cheers, Aus Quote Link to comment Share on other sites More sharing options...
Swervomotor Posted May 20, 2020 Report Share Posted May 20, 2020 I would look at: SD card present? SD card formatted correctly (fat32) Max number of files on SD card not exceeded (this is a set-able number in unilogic) Make sure you are not resetting the contact that starts the save in the same rung (I remember this was an issue for me for some reason) I would then email Support: support@unitronics.com Quote Link to comment Share on other sites More sharing options...
louisgermain6 Posted May 21, 2020 Author Report Share Posted May 21, 2020 @Ausman, Sorry for all the posts, the page was going to an error when I was submitting the reply so I thought they weren't even send.. Thanks for understanding. @Swervomotor, All that conditions are OK, so I guess I'll have a shot with the support Thanks a lot guys ! Quote Link to comment Share on other sites More sharing options...
