chetan erande Posted July 14, 2020 Report Share Posted July 14, 2020 Hi, We are using Unilogic version V1.29.111 . While working on the alarm summary screen, we noticed that there is very little space to add the alarm description, which is called as "alarm name". Operators are not happy with this as they are familiar with AB and Siemens HMI which has ample space to add alarm description. Is there any way to widen the alarm name column or add two line in each row under this column Quote Link to comment Share on other sites More sharing options...
