Pierro Posted July 21, 2020 Report Share Posted July 21, 2020 Hi everyone ! Currently, I use a Unistream PLC Built-in 5", the US5-B10-B1 and it's very nice to use ! However I have a question. I'm currently programming the alarms and i'd like to use the built-in alarms on Unilogic, but all the interface are in english even though the software is in French. Before creating this topic, i searched and found something but on Visilogic. Apparently, we can translate the text in the source files but I don't know where it is... Here the topic : It is posible on Unilogic to change the language of the alarms display ? Thanks ! Quote Link to comment Share on other sites More sharing options...
Annatooli Posted July 22, 2020 Report Share Posted July 22, 2020 I did wonder it, until I loaded the program into PLC and discovered that even when Unilogic shows interface in English. In real PLC it is translated. At least it was case with Russian. Anatoly Quote Link to comment Share on other sites More sharing options...
Pierro Posted July 22, 2020 Author Report Share Posted July 22, 2020 Thanks, I changed the language of the PLC and it works. Quote Link to comment Share on other sites More sharing options...
