MVP 2021 Flex727 Posted July 22, 2020 MVP 2021 Report Share Posted July 22, 2020 I just discovered that if I have Ethernet connection "Favorites" saved in a project file then open that file on a different computer, they are no longer there. Am I missing something? I am using version 1.28.34. Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 22, 2020 Report Share Posted July 22, 2020 The favorites are part of the computer (not specific to a project), so if you open a different project, then you have the same PLCs appear in your favorites. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 22, 2020 Author MVP 2021 Report Share Posted July 22, 2020 7 hours ago, Saragani said: The favorites are part of the computer (not specific to a project), so if you open a different project, then you have the same PLCs appear in your favorites. This is terrible in my opinion. Connection settings are project specific and need to be saved with the project. Quote Link to comment Share on other sites More sharing options...
Saragani Posted July 22, 2020 Report Share Posted July 22, 2020 Isn't the favorites in VisiLogic behave the same? Maybe an enhancement would be having 2 tabs in the favorites dialog: Global favorites and Project favorites, where the last one is loaded from the project. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 22, 2020 Author MVP 2021 Report Share Posted July 22, 2020 5 hours ago, Saragani said: Isn't the favorites in VisiLogic behave the same? No, in VisiLogic the favorites are saved with the project and are specific to the project, as they should be. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 23, 2020 MVP 2021 Report Share Posted July 23, 2020 Flex has a valid point. Typically the Ethernet address is part of the project. We save all our project files to a server, and my personal situation is there is a one in five chance that the program will be opened by a different computer. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 23, 2020 MVP 2021 Report Share Posted July 23, 2020 Hmmmm.....in Visi, ALL my favourites are saved in the evb file. Hence my solution to the "security" issue here, which is also in the "not quite pinned" list: http://forum.unitronics.com/topic/5439-hiding-remote-locations-on-your-pc-from-crooks/?tab=comments#comment-21086 It would be nice if only the relevant details were saved on each project. After all, if you've got it open, you probably want to use it! I don't use the key of my car to just hop in and sit there making vroom vroom noises. Well......sometimes I do. 🏎️ cheers, Aus Quote Link to comment Share on other sites More sharing options...
Cam Posted July 28, 2020 Report Share Posted July 28, 2020 Doesn’t the project settings radio button provide this ?? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 28, 2020 Author MVP 2021 Report Share Posted July 28, 2020 45 minutes ago, Cam said: Doesn’t the project settings radio button provide this ?? What project settings radio button? Quote Link to comment Share on other sites More sharing options...
Cam Posted July 28, 2020 Report Share Posted July 28, 2020 Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 28, 2020 MVP 2021 Report Share Posted July 28, 2020 Yes. Yes, it does. But we're crabbing about this feature being missing from UniLogic. 😄 Joe T. Quote Link to comment Share on other sites More sharing options...
Cam Posted July 29, 2020 Report Share Posted July 29, 2020 🥴Opps I missed that. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted January 5, 2021 Report Share Posted January 5, 2021 Will be included in the next UniLogic version! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 5, 2021 Author MVP 2021 Report Share Posted January 5, 2021 3 hours ago, Cara Bereck Levy said: Will be included in the next UniLogic version! Thank you, Cara! 1 Quote Link to comment Share on other sites More sharing options...
