louisgermain6 Posted July 23, 2020 Report Share Posted July 23, 2020 Hey guys, I'm currently using a US7-B5-TR22 and I made a little washing program for some piping. The idea is to open the valve and wash the first pipe during a certain amount of time and when it's over, we start to wash the second one, until we wash all the lines and stop the system. My times are set before and so when the phase starts, it should start the timer at the preset value which is stored into the current value. Everything works well, except at the beggining of then program, the first pipes which has a timer of 00:04:32:000 always starts with a different value and the foolowing ones starts with the good value. I can't understand why it doesn't work because the logic is the same. If you need some more explanation just tell me. Thanks in advance for your help Louis Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted July 23, 2020 MVP 2021 Report Share Posted July 23, 2020 Post your program here so we can help you. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted July 23, 2020 MVP 2021 Report Share Posted July 23, 2020 Or change your thinking and use a count of your own making. Cascading timers can work, but can also be an endless source of problems. The beauty of counts is that you can manipulate things much easier on complex progressions. "Hmmmm....run that process.....from here to there". Timers do make part of this sort of thing easier, but if your timer initiation/ending goes astray you can easily get headaches. To get around the issue of using counts, you can do "invisible to the user" maths to make the count adjustments automatically allow for any changes in the total progression. cheers, Aus Quote Link to comment Share on other sites More sharing options...
louisgermain6 Posted July 24, 2020 Author Report Share Posted July 24, 2020 Crazily I resolved it by starting the cascade with a false timer of 5ms and the other ones initialise as it should. Thanks for your suggestion @Ausman Quote Link to comment Share on other sites More sharing options...
