Albert110 Posted August 24, 2020 Report Share Posted August 24, 2020 I have been using Samba now for some years and some of them have started to loos data because of battery low. My question is, is it possible to replace the battery in Samba 3.5 and 4.3 versions with power on? I know it is possible in the 7" by just removing the back panel, but it doesn't look possible on the smaller one, is that the case? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 24, 2020 MVP 2021 Report Share Posted August 24, 2020 In SM35 and SM43 for battery replace user need to remove IO card. So, battery cannot be pelaced with powered PLC. If project is present - you can Download All & Burn for not lost project in PLC and upload operand to file for not lost memory value. You can easly download it after battery replace. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted August 25, 2020 Report Share Posted August 25, 2020 Look at Unitronics Helpdesk artille: Vision PLC battery change without losing datahttps://support.unitronics.com/index.php?/selfhelp/view-article/vision-plc-battery-change-without-losing-data Quote Link to comment Share on other sites More sharing options...
