Is there any way to convert a visilogic program to unilogic?
TozoM8
I found when I went to move a program from Vision to UniStream that there were a significant number of differences between the way Vision does things and the way UniStream does things.  Some function blocks available in Vision do not exist in UniStream, such as PWM.  Data tables are different as well, for example.
Tags and structure variables are a whole 'nother topic in the differences.
You have to go back and look at your program  and translate it, unless you choose "New (Pre-Defined Tags)" which will create arrays of tags with the same names as the Vision series.
This is good if you're doing a straight push and your logic is mostly basic operations.
