Problem with V350 + Sinamics G120
Hello everybody! Please I need some help!
I´m trying to command a G120 with  a V350 via modbus (over Rs485 - two wires). The communication its ok, but I can´t change to Run status the inverter.
The Starter display the following:
My program is the following
First: I write 0x47E in the parameter 40100
Seond: I write the Main Set point in the parameter 40101
Third: I write the command 0x47F in the parameter 40100
if someone can send me an example or give me some help, I will be very grateful!!
Thanks a lot!!
Mario
Hi,
Some quastions:
1) Is it speed and 8E1 (simens default) settings  commisioned corectly in V350 com settings?
 2) Is it G120 setpoint channel sw. = Modbus, Control channel = Modbus?
3) Is it G120 correctly commisioned and all self autotune done and all autotune settings written to the drive . Drive do not allow to net control before autotune done (default).
4) What is with modbus status when command was send?
maybe this document is useful:
https://static1.squarespace.com/static/5357e4cfe4b02760ee8a9506/t/53ecf6f2e4b03c7a36fcfed3/1408038642976/MicroBridge+Modbus+Plus+to+G120+App+Note.pdf
chapter Verifying the Installation
On 10/10/2020 at 11:41 PM, Joe Tauser said:
Do you have the wired Enable signal on the drive terminals connected (DI0)?
Hello Joe, DIO es connected to a sensor, The signal is ok I try with DI0 in ´1´ or ´0´ but the result is the same, the inverter is stopped.
All the inputs have the right connection and I chek if the signals are OK.
All is ok, but the problem persist.... 😞
On 10/10/2020 at 4:35 PM, kratmel said:
Hi,
Some quastions:
Hi!,
First of all, thanks for your time!. I respond your questions:
The comunication it´s ok because I can write and read diffents parameters (I set 8 bits, Even and  1 stop bit)
I can´t find the control channel parameter.
Autotune is done
The modbus Status is 0 (communication OK
On 10/13/2020 at 3:30 PM, kratmel said:
Hi, in
chapter of document in my above post present Modbus registers that can be sw. OFF1 bit directly.
Please try to do this for test - it is the same idea as Joe provide with DI0 but via software.
Hello!
I try set the parameter 40003 ( number 2 in visilogic) but the communication state change to "5". Another question, the "big endian" formtat, used by Siemens, could be  the origin of the problem?
Thanks for your time and help!
Best regards
Mario
On 10/16/2020 at 6:59 PM, kratmel said:
Great news.
If it possible - please select by red ink parameters in table that you change for rectify problem.
And this table can be useful for another forum users.
Hello,
I can solve my problem setting the G120 parameteres like the information of the table (parameteres marked in yellow)
Best regards!
Mario
  • Like 1
