razor_rich Posted July 17, 2011 Report Share Posted July 17, 2011 Hi. I have a V130 and I'm setting up an Enhanced Web Server. Is there any way to be able to write strings from the web page to the PLC like you can write MIs? I'm trying to set up the ability to enter an email address in the webpage as a string, and then write it into the PLC's string libary, and if not, an MI vector. Then I want to call this string in the email FB as an indirect vector of MIs. Unless there's a better way to do this. Also, I noticed a typo in the "Enhance Web Server.pdf" support file. On page 6 where it describes the string syntax, there's a comma missing between the string number and the placeholder characters. I believe the format should be [sTXXXX,PPPPPPP] and not [sTXXXXPPPPPPP]. I've found that if the comma is missing, only the 0 string in Library 1 is displayed. Quote Link to comment Share on other sites More sharing options...
Ofir Posted July 18, 2011 Report Share Posted July 18, 2011 Hi, There is no option to write string from the web page to the PLC. As you mentioned the workaround to do it is only writing ASCII values to consecutive MIs which is not so elegant way. Indeed you are right regarding the document (the comma is missing) and we will fix it. Quote Link to comment Share on other sites More sharing options...
razor_rich Posted July 18, 2011 Author Report Share Posted July 18, 2011 That's okay. I figured out how to do it on the HMI with a "Variable: ASCII String." Thanks for the quick response. Quote Link to comment Share on other sites More sharing options...
