JozefSVK Posted November 18, 2020 Report Share Posted November 18, 2020 Hello guys I need help I have unitronics plc US5-B5-TA30 and I´m really satisfied with this product. I want connect encoder via high speed inputs. Encoder will be for HMI because we dont want use touch, only encoder so we need left, right and click. I was testing this type of encoder (alps alpine EC11B). When I put there 24V it was worked perfect, but in datasheet they write max voltage for encoder is only 5V. Is there any solution how I can do it ? Thanks for your answer Jozef Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 18, 2020 Report Share Posted November 18, 2020 JosefSVK, You have to follow Data Sheet if you wish to have encoder working for long time. 1. You have to supply 5V to encoder. 2. You have to use TTL (from encoder) to High Level (0...+24V) converter. Such Signal Level Converters are supplied by different companies - DigiKey, Sparkfun, Element14, etc. Hope this information helps. B.R. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 19, 2020 MVP 2021 Report Share Posted November 19, 2020 This type of encoder has no electronic part inside - then only 2 contact with common wire for AB signal and NO contact for button. 10mA 5V signal provided. As we see in US5-B5-TA30 - Input work with 24V 8mA max signal. Then you can use it for US5-B5-TA30 PLC but contact life is hard to predict. As for me - this type of encoder used inside of device mounted on pcb with minimum wire length to 5V powered MCU. Then better solution - use industrial grade encoder 24VDC rated and IP65-67 design. Quote Link to comment Share on other sites More sharing options...
JozefSVK Posted November 19, 2020 Author Report Share Posted November 19, 2020 Thank you guys for your answers. As Kratmel is writing best solution is use encoder with 24VDC. But I was looking everywhere and i cant find encoder (a, b signal and also click function) for 24Vdc only for 5V. If you now name please write it to me and i will be most happy man in the world :-D. I dont want convert my 24vdc to 5vdc put it to encoder and back with level shifter to 24vdc, but it looks to use signal level shifter is only one option what I have. If you have some idea please write me. Thank you all !! Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 19, 2020 Report Share Posted November 19, 2020 One for example: https://docs.rs-online.com/de8c/0900766b813fa4b5.pdf Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted November 19, 2020 MVP 2021 Report Share Posted November 19, 2020 38 minutes ago, AlexUT said: One for example: https://docs.rs-online.com/de8c/0900766b813fa4b5.pdf There is no button inside. https://www.shanpu.com.tw/en/product/tags/1/Rotary-Encoder-switch But only 10VDC sample present... Quote Link to comment Share on other sites More sharing options...
AlexUT Posted November 19, 2020 Report Share Posted November 19, 2020 I have no time to search. Give just example. If nobody has ready to give link - then JosefSVK should spend his time and search... Rem. By the way, provided link show that encoder will work with 115V. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 19, 2020 MVP 2021 Report Share Posted November 19, 2020 I use these guys often in the US - https://www.autonics.com/product/category/2000013 Find something with the "T" or "V" output for 24 VDC. Joe T. Quote Link to comment Share on other sites More sharing options...
