sjump Posted November 25, 2020 Report Share Posted November 25, 2020 I am having trouble connecting my PC to the PLC. I have tried both the ethernet and the USB port. Could some one help point me in the right direction on solving this issue? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 25, 2020 MVP 2021 Report Share Posted November 25, 2020 Your information is a little sparse here for anyone to provide any useful help. Which PLC model? What happens when you try to connect with USB? Have you tried using a different cable? Have you tried reinstalling the driver? For Ethernet, what is the IP address of the computer and the IP address of the PLC? Are they on the same subnet? Are you using either a crossover cable or an Ethernet hub? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 25, 2020 MVP 2021 Report Share Posted November 25, 2020 The first question when this happens is "Did you run the installation program as administrator?" If not, communication may be blocked. Let us know. Joe T. Quote Link to comment Share on other sites More sharing options...
