giladn Posted December 6, 2020 Report Share Posted December 6, 2020 I'm using the CRC function block with "CRC Enum Type.CRC32" and it calculate correctly.....but the string coming in is in HEX format and when I try to convert the CRC from the sting to the one I've calculated using the CRC block I have to use the "String To Num" function block which is working only on ASCII dose anyone have a solution to how to verify CRC in this situation? Thx Gilad Quote Link to comment Share on other sites More sharing options...
