Append buffer to SD file...how to have a "new line"?
ORSO2001
Dears All,
i am concatenating 4 String UTF-16 formated; between the strings I insert a ";" separator (also UTF-16 formated)...so...I am able to have the end buffer properly filled with th einformation...but I am not able to have a "new line" when I try again to append the buffer at the SD file.
I tried to insert, at the end of the buffer, a lot of characters (u\2424; u\000D; u\000A...etc alone and conbined )...but nothing works...or better...with the file saved as TXT and with the u\000D in the "windows note pad" I see the right lines...but if I use "notepad ++" or i try read this as CSV i have a long single line.
how to have a "new line" ?
thanks
