kvj Posted December 29, 2020 Report Share Posted December 29, 2020 Hi, I have a situation to troubleshoot V570 because of unexpected behavior on the program. I was given a program file. How can I compare if the program file given is the same as the loaded program to the PLC-HMI ? (the program cannot be uploaded) Is there anyway to do this? Thanks. Regards, kvj Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 29, 2020 MVP 2021 Report Share Posted December 29, 2020 No, there is not, but you can look at the file name for the .vlp file loaded in the PLC in INFO Mode and compare it to the file name of the program you were given. That may help you some. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted December 29, 2020 MVP 2021 Report Share Posted December 29, 2020 Didn't you just ask this question last month? Quote Link to comment Share on other sites More sharing options...
kvj Posted December 30, 2020 Author Report Share Posted December 30, 2020 Hi Flex, Thanks. Yes, I did. My laptop crash and needs to restart everything, and all my infos gone and I repost my question only to realize later. There is also a suggestion called to VERIFY on the menu, from my previous post Compare project file to online program Visilogic - Vision & Samba PLC + HMI Controllers & VisiLogic Software - Unitronics Support Forum: Programmable Controllers (PLC + HMI All-in-One) Regards, kvj Quote Link to comment Share on other sites More sharing options...
