ScottF Posted January 8, 2021 Report Share Posted January 8, 2021 Customer has requested the ability to set, and monitor the temperature at remote station(s)/location(s) on a printing press. Any simple way to do this using another V350xxx without a major programming effort??? Basically want to duplicate the buttons and display, and have them work in parallel with the existing full control. Serial connection ok, or? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 9, 2021 MVP 2023 Report Share Posted January 9, 2021 Put an Ethernet card in the V350 and put Remote Operator on a PC connected to it. Joe T. Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted January 9, 2021 Report Share Posted January 9, 2021 Joe recommended this to me awhile back and it works great. Added plus that you can use teamviewer to get into visilogic and the plc easily. Often hard to deal wit IT to have access to the network. This way I just install a touchscreen laptop as a secondary screen and connect to wifi as a guest. No company sensitive info is accessible, but you have easy access to the plc. Quote Link to comment Share on other sites More sharing options...
