Jungletron Posted January 22, 2021 Report Share Posted January 22, 2021 Hello, I can read and write a setpoint (=BACnet object I want to control) with my computer BACnet program (YABE). I can see UniStream BACnet server in the same computer program. But how do I make the PLC read/write the BACnet object (=setpoint) ? Is the UniStream BACnet server enough? I really appreciate any help/advice. JT Quote Link to comment Share on other sites More sharing options...
pascal Posted July 7, 2021 Report Share Posted July 7, 2021 Same question here.... I need to communicate with a Schneider Electric BMS module, via BACNET. With YABE (free bacnet explorer) I can see both bacnet devices, but how the hell can I read the schneider output into my unilogic plc and write some data to schneider via bacnet ? Quote Link to comment Share on other sites More sharing options...
Jungletron Posted July 7, 2021 Author Report Share Posted July 7, 2021 Hi Pascal, What I concluded from my little experience is that to use the PLC to read sensors and write setpoints in a BACnet server it is necessary to have a Unitronics BACnet gateway. This gateway will provide a BACnet client in the PLC. Stay safe. JT Quote Link to comment Share on other sites More sharing options...
