georgegraz Posted July 22, 2011 Report Share Posted July 22, 2011 I am new to the Jazz. What I am trying to do is, use the screen to set a timer variable (15 to 30 Minutes) that a pump will run, then use the Number 1 key to start the pump. It will run for the amount of time set, then shut off. It can be shut off ahead of time with the number 0 key. I can't seem to set the timer preset to what I entered in the 1st part. Could someone give me a nudge? Thanks George Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 24, 2011 MVP 2021 Report Share Posted July 24, 2011 Could you attach your program? Joe T. Quote Link to comment Share on other sites More sharing options...
