Naoto Posted August 30, 2010 Report Share Posted August 30, 2010 I'm using Vision120 and want to receive serial message from DRO. The message format is follows X=999.9999 Y=999.9999+cr+lf or X=-99.9999 Y=-99.9999+cr+lf The leading zero will be supplessed by space. Total length is fix. Integer value is vary and signed. In front of Y is space. When I setup Protocol Scan FB as X=111111111 Y=222222222+ETX 111111111 is defined deciaml ASCII fixed length, vector=1,decimal point=MI20(10000), Lenhth=8 prefix=-(negative) only, link ML1 ETX is defained as length=2, 1st one is 0D, 2nd one is 0A. 222222222 is defined deciaml ASCII fixed length, vector=1,decimal point=MI20(10000), Lenhth=8 prefix=-(negative) only, link ML2 ETX is defained as length=2, 1st one is 0D, 2nd one is 0A. The FB protocol config return status code=258 (Invalid message) When I setup as 111111111111111111111+ETX 111111111111111111111 is defined as stream vector length 21, convert 1 receive bite to 1 liked element,Link=DW0 This code can success. And message stored correctry. But It are word data, and need to convert numerical data. It is not smart. Does anybody knows the correct setting for this message format? Naoto Quote Link to comment Share on other sites More sharing options...
Emil Posted August 30, 2010 Report Share Posted August 30, 2010 Hi Naoto, Try to define two messages in FB Protocol Scan. For X variable one will be with no sign and the second with negative sign. Y variable can be set as not fixed length - in both defined lines. Let me know the result. Quote Link to comment Share on other sites More sharing options...
Mike Posted September 23, 2010 Report Share Posted September 23, 2010 Another quest about Protocol : I'm using V350-TU24 and want to receive message like " >1[CR] "  after request  (Send " &321[cr] ")  via Port2  RS485. STX and ETX  of Scan  sets  for  3E  (i.e.">")  and  0D  ([cr]).  Pattern message=  "1" When I send legal message from the hex terminal  "  3E 31 0D  "  , V350 recognizes this message as alien -  Index= -1 ,  Session complete=0 When I add at begin "0D",  and send "  0D 3E 31 0D  "  ,  all working properly.  But why this 0D ?! ! if I try to turn off the step Send request,  it works without  0D ..  and with 0D..  But the efect on the "Number recieved bytes" .. Serial monitor of the V350 info mode displays everything correctly. Visilogic 8.6.1.  OS of V350 updated. HELP Quote Link to comment Share on other sites More sharing options...
