DANIEL126 Posted February 5, 2021 Report Share Posted February 5, 2021 Hi, I hope you can help me. I need to do an Summary de MI. For example: I need to add a range of MI (MI 0 to MI 60) an copy in MI 100. Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 5, 2021 MVP 2021 Report Share Posted February 5, 2021 Moved to the correct forum. There is a math function to add up to 8 MIs. You could do that 8 times to get your 61 MIs added together, or you could develop an algorithm using indirect addressing to add them over multiple PLC scans. Quote Link to comment Share on other sites More sharing options...
