John_R Posted February 16, 2021 Report Share Posted February 16, 2021 alright Fellas, riddle me this.......... I have a V570 out in my workshop, one of its duties is control of the heaters in two different rooms. On the Heat Control display I have a couple of indicators (binary images linked to outputs) that turn green when the output to the heater relay is on. Which works as it should when in debug from Vision (and on the V570 itself); But when I go to Remote Access to look at the same display (from the same PC), my indicators do not work; I first thought it was because I had an older version of Remote Access install, so I replaced it with the newest version, same results. Anyone have any ideas why it does this? JohnR Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 16, 2021 MVP 2021 Report Share Posted February 16, 2021 You have to tell Remote Access to upload the PLC's images and create a local use file- Joe T. Quote Link to comment Share on other sites More sharing options...
John_R Posted February 16, 2021 Author Report Share Posted February 16, 2021 Well, once again Joe, you are correct But the bizarre thing is that in all my years using Remote Access "back at the plant", I've never had to do that??? JohnR ⛄ Quote Link to comment Share on other sites More sharing options...
